250r oil check???
Old May 5, 2002 | 09:20 AM
arsonist678's Avatar
I stripped our the oil check bolt on my r
is there a way to machine out a spot on the cases cover
to put a sight glass to check the oil or do i just have to
re tap the hole and get a bigger bolt
Old May 5, 2002 | 10:45 AM
GR8T250R's Avatar
I think you can retap or use a self-tapping bolt to fix this at home. Go to the 250rforum@ezboard and search this topic. I'm sure it has been discussed.
Old May 5, 2002 | 12:03 PM
atc86r's Avatar
what did you do to do this? overtighten or cross thread. when reinstalling bolt spin bacwards half turn or so till u feel it line up and sink in a little then install. overtightening is easy to do if you dont use torque wrench have to be real careful. those engine case bolts strip easy also.
Old May 5, 2002 | 02:05 PM
the dude i bought it from must have stripped it out because when i got it it was a bolt not a screw like the pichure in the manual
i checked the oil a few times and it then it stiped out
i whanted to know if i could make it a sight window insted of the check bolt
because it would be so much simpler
if i could get it machined out so i could put a window like on the front brake resivour
Old May 5, 2002 | 03:47 PM
KILLER250R's Avatar
It's not like your burning your transmission oil so the site glass really wouldn't be worth it, just take out the bolt everyone once and a while and check it, it's not that hard.....[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 6, 2002 | 12:24 AM
2fun's Avatar
Just re-tap, and go with the next size up (metric of course).
Remove the case BEFORE tapping. You don't want aluminum shavings in there.
slowgsxr97
Mar 18, 2022 03:40 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
