Raptor wiseco 11:1 piston
Old May 9, 2002 | 05:42 PM
WreckRaptor660R's Avatar
I have a 11:1 compression pistion in my raptor. The bike is stock, execpt for a jet kit. WHat i need to know is... When adding compression, will this require me to re-jet? it does idle a little loopy now, but it seems to run ok, however am I losing power by not upping the jet size...I am getting a pipe soon, and will re-jet then, however, i need to know can i use dybo-jet's reccomended jetting for a stock bike with a slip-on and will the jetting be ok then? thanks
Old May 9, 2002 | 06:34 PM
vraptor's Avatar
11:1 stock bore no reason to up your jets
Old May 9, 2002 | 09:53 PM
wshrdskin's Avatar
Doesn't a higher compression piston, require a new cam to accomadate? To get the best out of the higher comp piston? Isn't having this higher comp piston pretty much a waste without a cam, springs, valves to go with it?
bmxatv10
Oct 14, 2022 06:23 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
black_thunder
Sep 22, 2015 07:59 PM
