84 Raptors take 2 (actually 90 Raptors)
Old May 9, 2002 | 08:44 PM
velocityraptor's Avatar
Ok lets try this again. [img]i/expressions/face-icon-small-mad.gif[/img]
How many of you have taken your Raptor motor mods to the next level? I'm not talkin pipes, I'm talkin big bore, high compression etc. I dont want to know what you have had done, just simply reply I.
The ones I already know of are;
Myself
14mins
herbdon
Zombie660r
Raptor720
Kingraptor
Teamsparks
airraptor
Lafngas
RichieRoadrash
Old May 9, 2002 | 08:51 PM
ltracerx's Avatar
I am just curious, how did you come up with 90 Raptors?
Old May 9, 2002 | 08:54 PM
<< I am just curious, how did you come up with 90 Raptors? >>
There is a few on here that I know of that didn't reply to the previous post.
Why, whats the problem?
Old May 9, 2002 | 08:58 PM
P.S. IF YOUR NOT A RAPTOR OWNER, PLEASE DO NOT REPLY TO THIS POST! (Bansheebrad)
Old May 9, 2002 | 09:46 PM
lafngas's Avatar
I
Old May 9, 2002 | 10:06 PM
02raptorboy's Avatar
not I
Old May 9, 2002 | 10:33 PM
kingron's Avatar
Just recieved my Armadillo swing arm skid plate and new rear rotor today. Otherwise still stock. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2002 | 11:24 PM
Zombie66or's Avatar
I
Old May 10, 2002 | 03:35 AM
raptor720's Avatar
1. 686. 102mm J&amp;E piston 10.5:1 with some spec work. HD clutch springs, FCR's, WebCam, stainless valves, springs, retainers, port work, chamber mods, stock modified head pipe and GYTR tip, opened air box, white bros filter.
2. 727. 105mm J&amp;E piston 10.5:1 with some spec work. HD clutch springs, FCR's, WebCam, stainless valves (big intake), springs, retainers, port work, chamber mods, stock modified head pipe and GYTR tip and/or Trinity Stainless dual exhaust, open K&amp;N's and some ignition work.
3. ???. 105mm J&amp;E ??.?:1 with major spec work, ???mm stroke, Carillo rod or ??? rod, very custom rings, ???? cylinder liner, custom roller timing chain or belt, special clutch basket, plate and springs, 39/41mm FCR's or fuel injection, custom spec cam, ????? valves -- ??mm, springs, retainers, major port work, major chamber mods, Trinity exhaust, open K&amp;N's, Custom/special ignition system, ???? gear set, etc.
Old May 10, 2002 | 06:11 PM
Ward660R's Avatar
V you can add RichieRoadRash to your list as he has a high comp piston and cam from FST.
