84 Raptors take 2 (actually 90 Raptors)
Ok lets try this again. [img]i/expressions/face-icon-small-mad.gif[/img]
How many of you have taken your Raptor motor mods to the next level? I'm not talkin pipes, I'm talkin big bore, high compression etc. I dont want to know what you have had done, just simply reply I.
The ones I already know of are;
Myself
14mins
herbdon
Zombie660r
Raptor720
Kingraptor
Teamsparks
airraptor
Lafngas
RichieRoadrash
Myself
14mins
herbdon
Zombie660r
Raptor720
Kingraptor
Teamsparks
airraptor
Lafngas
RichieRoadrash
1. 686. 102mm J&E piston 10.5:1 with some spec work. HD clutch springs, FCR's, WebCam, stainless valves, springs, retainers, port work, chamber mods, stock modified head pipe and GYTR tip, opened air box, white bros filter.
2. 727. 105mm J&E piston 10.5:1 with some spec work. HD clutch springs, FCR's, WebCam, stainless valves (big intake), springs, retainers, port work, chamber mods, stock modified head pipe and GYTR tip and/or Trinity Stainless dual exhaust, open K&N's and some ignition work.
3. ???. 105mm J&E ??.?:1 with major spec work, ???mm stroke, Carillo rod or ??? rod, very custom rings, ???? cylinder liner, custom roller timing chain or belt, special clutch basket, plate and springs, 39/41mm FCR's or fuel injection, custom spec cam, ????? valves -- ??mm, springs, retainers, major port work, major chamber mods, Trinity exhaust, open K&N's, Custom/special ignition system, ???? gear set, etc.
