Jetting
Old May 12, 2002 | 04:17 PM
Some1's Avatar
I have a Toomey B1 pipe/silencer, Reed spacer and aktive reeds. I know the Toomey is a topend pipe but should it bog down in the low end? Heres some pics of the new plug I took out after about 2 hours of riding. http://photos.yahoo.com/bc/gfx16/lst...tos.yahoo.com/
Tell me what jets a should be using ect, thanks.
Old May 12, 2002 | 04:48 PM
99blueblaster's Avatar
If that is a new plug with only two hours on it you are rich. Before you mess with jetting make sure your air filter is clean and oiled properly. What is your jetting now( needle and main) ?
Old May 12, 2002 | 05:23 PM
Some1's Avatar
The filter at the time was semi dirty but oiled well. I'm running a 310 main which came with the pipe, and the needle is at the 3rd groove from the top.
Old May 12, 2002 | 05:44 PM
Other mods? air box? stock needle or lrd?
Old May 12, 2002 | 05:49 PM
Some1's Avatar
Stock needle, only other mods are what I listed.
Old May 12, 2002 | 06:14 PM
drop the needle back to stock setting(second groove) and drop you main to a 290. It looks like you are very rich. Your needle and main settings are kind of big for no air box mods.
to give you some kind of comparison I have FMF fatty and silencer, no snorkle, uni air filter, and carbon tech reeds. I run a 270 main, 2 clip needle setting, stock pilot, air screw out 2 turns. I run at 1500ft and my plug readings are alittle rich but doesnt foul plugs.
Old May 12, 2002 | 08:40 PM
Some1's Avatar
I just took the carb apart, it's not a 310 like they were supposed to put in(I had a racing company put all the mods on). The main jet is a 250, how can it be running that rich with only a 250!?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
