just recived motor and it will not start.
Old May 13, 2002 | 07:10 PM
maximus's Avatar
i just got my motor back from rick ritter, and i installed it and it will not start. it will turn over but it sounds like the starter is trying to drag some. now i did not bolt the ground down from battery yet. i just had it against metal. could this be it. it is getting gas. also it has been since feb. since i have cranked motor on the battery. maybe a week battery. any help would be helpful
Old May 13, 2002 | 09:31 PM
RickRitter's Avatar
Hmmmm ... Call me ... 618-644-3211
Rick
Old May 13, 2002 | 09:39 PM
killerkx327's Avatar
it would make sense if you connected everything and made sure the battery was up to full charge before you even try to start it.
Old May 13, 2002 | 09:52 PM
Gramps's Avatar
Have you tried the pull start .
Hey Rick I think all the bugs are gone now , went riding this
weekend no tow rope needed . Piston and ignition held up , very
pleased with the mid range pull and exceleration . Now I know
how poor the suspension is . Thanks for all your service and help .
Old May 14, 2002 | 12:28 AM
RickRitter's Avatar
You are welcome Gramps . I am happy it is working well for you.
Old May 14, 2002 | 01:49 PM
maximus's Avatar
ok. everything is ok. just the ground wire comming off battery. runs like a top
Old May 18, 2002 | 10:36 PM
atc86r's Avatar
I also am having a problem with no spark. I checked my ground disconected the etc on the trottle and still am not getting any spark. I got help by someone with the same mods on his scrambler as I do. He thinks that it might be my cdi or coil pack. Anyone have any help?
rcr trail port
Old May 19, 2002 | 01:48 PM
powerslider's Avatar
just a wild guess but the magnet didn't separate from the flywheel did it?
Old May 20, 2002 | 11:49 AM
atc86r's Avatar
maybe, only took off cylinder and oil injection.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
quickwhips
Sep 2, 2015 06:53 AM
