Scrambler Transmission ?
Old May 14, 2002 | 05:30 PM
dillas23's Avatar
I have a 95 Scrambler that I am restoring. My question is, will a newer model transmission fit into the frame? The trans that has the hi/lo option. Would it be beneficial or a hinderance?
Old May 14, 2002 | 06:31 PM
HondaRyder's Avatar
Oops, Sorry I responded to the rong post. [img]i/expressions/face-icon-small-tongue.gif[/img]
He he
Old May 14, 2002 | 06:51 PM
Rockey's Avatar
I don't know if it will fit but if you are interested in a transmission from a 99 Sport 2wd I can give you one for half the price of a new one. Good luck
Old May 14, 2002 | 08:39 PM
dillas23's Avatar
I e-mailed you earlier about the starter and the carb. I guess you didn't get it. I don't know if it will work with the 4x4 or not. Does anyone else know? Also, does it have hi/lo?
Old May 14, 2002 | 09:37 PM
Rockey's Avatar
Ah, no it won't work. I forgot you were going with 4wd. Mine only has Hi and reverse. BTW, you have mail.
Old May 14, 2002 | 10:41 PM
500SCR's Avatar
Yes, the tranny is a direct swap if you can find one with chain drive for the front and it needs to be from an Explorer. You could change yours to shaft drive for the front if you wanted. This is a much better setup and you can find the newer tranny's much easier. I have a '99 Scrambler 4x4 tranny with reverse and high but not low. This is shaft driven for the front and I will sell it for $500.
Scott
Scrambler Pics
Old May 14, 2002 | 11:02 PM
dillas23's Avatar
In order to change it to shaft drive I would have to change the whole front end.
Old May 14, 2002 | 11:07 PM
500SCR's Avatar
Just the differential, I believe the axle's are the same.
Scott
Scrambler Pics
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
