Raptor Neutral Light
Old May 18, 2002 | 11:25 AM
ANUFSED's Avatar
Lately after warm up and a small amount of riding my neutral light decides that it doesnt want to work some times. I have check the wiring and connections and everything lookd fine. Anyone have the same problem or a possible fix??
Old May 19, 2002 | 01:28 AM
yfm660r's Avatar
my neutral light doesn't work at all anymore, and when i ride hard for a while it doesn't want to go into neutral and sometimes won't, whats that mean ?
Old May 19, 2002 | 11:29 AM
ANUFSED's Avatar
Adjust it up on the perch?
Old May 19, 2002 | 05:03 PM
Turbo33's Avatar
Sounds like you will be replacing the clutch soon. When you do PM. me and I'll give you the numbers for the better clutch system for the Raptor. It will take a motorcycle clutch plate set up which includes 1 extra steel. I have switched both Raptors over and never have had the clutch fade problem again.I have also given the same setup to a friend that races the GNC Nationals and after burning out 3 clutches he put these plates in and has had NO problems since.
On a more serious note; whatever you do, DO NOT,DO NOT,DO NOT run the Barnett clutch plates in your four stroke.
Old May 23, 2002 | 11:02 PM
ANUFSED's Avatar
Ahh an adjustment fixed it so far. Thanks guys..
Old May 24, 2002 | 10:48 PM
Raptor58's Avatar
Turbo33
How a bout posting those #'s. my raptor is still pretty new but i'm tough on clutches so i might be changing them i a few months.
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
JoAnnS
Jul 23, 2015 02:18 PM
Derek Allen
Jul 22, 2015 09:25 PM
black_thunder
Jul 22, 2015 06:01 PM
