2002 Recon Pipe
Old May 20, 2002 | 09:57 PM
MOJAVE02's Avatar
my friend has a 2002 honda recon w/electric shift. if he went with the FMF Megamax2 would he have to rejet? what kind of gains will he see? also is the pipe very loud?
and what other pipes are good for the recon? thanks
Old May 21, 2002 | 07:39 AM
mudcovered's Avatar
I am planning on doing this mod myself soon. I don't know how loud it will be, or what gains to expect, but I have heard that you will need to rejet. Your only other alternative for pipes is the Supertrapp IDS-2.
Old May 22, 2002 | 06:45 PM
250rampage's Avatar
What I've always thought about doing is picking up a WB E-Series universal silencer. It's cheaper, a better pipe than the FMF or Supertrapp, and shouldn't take much if any modification to install since it has adjustible hangers on it. That's the route I was going to go with my recon before I decided to sell it.
Old May 22, 2002 | 09:27 PM
95wolv's Avatar
You won't really see a great improvement with just a silencer,the Hondas run such a tiny little pipe from the factory,the restriction would not let you get full benefit from the silencer. You will definately see a good power pick up with a pipe/silencer combo. I personally like the Supertrap IDS, having the discs inside keeps the mud and crud out of the spaces between the discs. The silencer choice is yours to make,but I would definately get a pipe also,to get every last bit of power available.
Old May 22, 2002 | 09:42 PM
250rampage's Avatar
A little trick you can do to increase airflow with the headpipe is to take it off, and grind down the little lip on the inside of the headpipe where it meets the head.
Old May 22, 2002 | 10:38 PM
redriderman's Avatar
explain that more 250rampage
Old May 22, 2002 | 11:11 PM
250rampage's Avatar
Alright, whenever you take off your headpipe, look inside the pipe where it meets the engine. There will be a little "lip" inside the pipe. This serves no purpose except restriction. So, I took a die-grinder and smoothed this out and polished it up to a mirror finish. Make sure you blow all the metal shavings out of the pipe then. Rember, a restricion right at the begining of the exhaust system robs more power then one at the end.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
Jason Campbell
Sep 7, 2015 02:25 PM
