400 EX Carb Slide Adjustments?
Old Nov 28, 1999 | 09:06 PM
mindcrime's Avatar
I remember within the last few months a few of you were talking about your misadjusted slides on your 400 EX's. They were adjusted from the factory where the slides would only open to the 3/4 position. How do you fix this? I've tried to find the past "Topic" but can't seem to find it to refer to. How good is YOUR memory? THANKS. :~)
Old Nov 28, 1999 | 09:23 PM
hot_shoe_cv's Avatar
mindcrime,
I didn't see the post you refer to, but at the cycle park I ride every week I 'm amazed at the number of throttles I twist that have a huge amount of slop in them...that's probably where you are finding a slide that does't raise completely. Check the play in your throttle, either twist or thumb. It should have just enough play to allow the bars to go full lock in either direction without increasing the RPMS. At that point your slide will open completely, barring some restriction in the carb.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Nov 29, 1999 | 12:36 AM
mindcrime's Avatar
I found what I was looking for. It was a note by 86atc250r posted on 09-11-99. It explains everything, thanks anyhow.
Old Nov 29, 1999 | 03:06 AM
86atc250r's Avatar
Was yours out of adjustment? Hope my post was helpful...
Gabe
'86ATC250R
'86ATC350X
'00TRX400EX
Old Nov 30, 1999 | 01:25 AM
mindcrime's Avatar
Thanks Gabe, the tip was greatly needed!!!
Countrygirl1976
Jul 13, 2015 10:08 AM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
