250R owners w/ FMF pipe and K&N, please read...
Old May 25, 2002 | 08:59 PM
meaniegreenie's Avatar
assuming you have a stock carb. what are main, pilot needle jet settings? I aslo have a Vforce reed valve. I think mine's off a bit. BTW, mine's an 86.
Old May 26, 2002 | 08:34 AM
BlueBus's Avatar
According to FMF's jetting guide it should be the same as stock which is: main - 145, pilot - 42 at 0-2000 ft and 70 degrees. For me these sizes are perfect at 50 to 60 degrees. Warmer than that and it seems a little rich. I was actually going to try a 140 for 70 degrees. My elevation is around 1100 ft. I don't know that helps you at all but I will say what most everyone will probably say too. The only way to really get it tuned in is by reading your plug. Just use this as a place to start. You maybe even want to start a little higher on the main. Better to foul your plug than your motor.
Old May 26, 2002 | 11:08 AM
trapperb1's Avatar
I have an 86, stock carb, Boyesen reeds, and a K & N.
Stock main jet for an 86 is a .150.
You have a pipe/silencer combo and better airfilter, this means you will need to increase the main jet by at least 3 sizes. ...152, .155, .158. Aftermarket reeds will cause you to be a little rich. I have my airbox lid off, and the snorkle removed. I ran a .160 for elevations over 3000, and a .162 for lower. The .162 worked at Glamis for me.
Do a plug chop (do several!). Best way to find out if you got it dialed-in. Each machine is going to react a little differently, so you need to tune your's on it's own basis. If you don't know how to do a plug chop, post it and I'll tell you how. It involves a lot of time but is easy to do.
Old May 26, 2002 | 06:04 PM
BlueBus's Avatar
Stock main for 86 - 145
Stock main for 87 - 150
Stock main for 88-89 - 158
www.fmfracing.com
Old May 28, 2002 | 02:11 AM
trapperb1's Avatar
I just gotta clarify this.
The stock main for an 86 is a .150
The stock main for an 87 is a .152
Info from my Clymers manual and my Honda manual.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
