WARN SELECT 424 INSTALED 02 RUBICON
INSTALED A NEW 424 WARN SELECT FROM MONTANA JACKS LAST WEEK IN MY 02 RUBICON. YOU WOULD NOT BELIEVE THE DIFFERENCE IN THE WAY THIS CHANGED THE OVER ALL MACHINE!!.BANG FOR BUCK I BELIEVE THIS IS ONE SOLID DEAL. AND I SUGGEST IT TO ANY ONE THAT WANTS THE 2WD=4WD OPTION.WHY HONDA DID NOT DO IT YET,I WILL NEVER KNOW.
REMOVED BOTH FRONT WHEELS,LEFT FRONT LOWER FENDER EXTENSION,INSIDE FENDER.4 BOLTS ON FRONT END ,SLED FRONT END FORWARD, REMOVED FRONT SHAFT.REPLACED WITH WARN SELECT 424,REVERSED PROCEDURE, THEN MOUNT CONTROL CABLE,A COUPLE OF BEERS,ABOUT 2 HOURS LATER.(PRICELESS)THEN WENT FOR TEST DRIVE.
Here's an up date on the warn 424.I received it on the 11th. and installed it on the 12th. It took about 3-1/2 hrs.Now that I've installed one of these units,I could do it a lot faster.
I took my wheeler for a short test drive,just to make sure that it worked,and for my money,it'worth every penny.
Installed the 424 Select on my 01 Rubicon last month and I highly recommend it. 3-4 hours install time.....be sure to grease the rubber boots and they will go on easier.
Performance is totally different in 2WD. Lots more fun to be had and you can always push the little red button and have the front wheels pulling again.
Jeff Roper
Feb 1, 2022 11:48 AM
jrooker6
Apr 23, 2016 07:36 PM
