go fast question
Old Jun 7, 2002 | 09:52 AM
jobaja's Avatar
for a baja what would be the next step in upgrading for speed, torque, and over all preformance if you already had
pipe, air filter, jetted, cdi, sprockets, and tires?
keeping in mind a price factor of under $1,000.
thanks
Old Jun 7, 2002 | 11:12 AM
Batoutahell's Avatar
my guess would be piston and cams and then a carb ugrade. You might be able to get all the parts for under $1000. But I dont know.
Bat
Old Jun 7, 2002 | 12:31 PM
sand45's Avatar
You should be able to buy high comp piston a set of cams and a 42mm flat slide carb and all the gaskets for the job. Right around 1,100 bucks thats if you do the work your self.
Old Jun 8, 2002 | 11:54 PM
Hurycne's Avatar
piston and cams are over $800. Dont forget the $250 springs!
John Reed
Sep 9, 2015 03:46 AM
MooseHenden
Sep 6, 2015 04:24 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
DGNAZ
Sep 5, 2015 09:14 PM
Logan Collins
Sep 5, 2015 08:03 PM
