Exhaust gas meter
Old Jun 7, 2002 | 11:08 AM
hinglbyds's Avatar
This is probably an odd question, but... Has anyone seen or heard of an exhaust gas monitor that will work on the DS?
The reason I ask is that I read an artical on top pro MX and rally racers. All of the pit crew for bikes, quads, cars ect. use an exhaust gas monitor to tune their engines. The artical even refered to Nascar using this device to set up fuel/air ratio. It was a good artical except it never said where to buy this gas monitor.
Anything will help.... Thanks
Old Jun 7, 2002 | 12:29 PM
TheFasterTheBetter's Avatar
Good EGA's (Exhaust Gas Analyzer) aren't cheap and require regular callibration. A Bacharat (not sure of spelling is correct) will run you $5000. They are not specifically built for one quad/car/etc. They simply have a probe that is insert up in the tail-pipe.
The guys with EFI (Scooby) use an O2 sensor that is mounted in the exhaust which constantly changes the fuel/air ratio via a micorprocessor. Can't do this with a Mikuni Carb.
I haven't heard of any easy ways of doing what you are talking about.
Old Jun 7, 2002 | 12:42 PM
dsguru's Avatar
Are they reading exhauts temp or the exhaust gases like HC,CO?.You can tune your motor with a exhaust temp gauge and they are alot cheaper.check them out a racepak.com.They make a nice one that would fit right in the console of the DS and it is waterproof can be used on watercraft.It is also a tach[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 7, 2002 | 02:05 PM
hinglbyds's Avatar
Thanks guys, that's what I am looking for. They are checking for CO, HC and EGT.
I can install a O2 sensor and map it to a fluke process calibrator but I was interested in the on board unit.
Thanks...
Old Jun 7, 2002 | 11:07 PM
BillDS650's Avatar
http://www.exhaustgas.com/
Old Jun 7, 2002 | 11:25 PM
ScoobyDFW's Avatar
I'm pretty sure they are talking about a portable wide band digital O2 meter. The cheapest they come are around $1000. I couldn't live without mine!
http://www.motec.com.au/plm.htm
http://thedynoshop.net/prod01.htm
Old Jun 7, 2002 | 11:58 PM
warrior007's Avatar
There was one in dirtwheels a few months ago, adapted from snowmobile racing, ran $500 though
Old Jun 8, 2002 | 10:38 AM
DDrecDS's Avatar
I used to have a Digitron meter on my Alky Banshee. It measured the Tach of each carb and the Temp of each Exaust.It had memory and auto shut down if it got to hot.It was from Digitron in Seatle, Sorry I sold the bike to get my Bomb or I would get more info off of it.It worked very well.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
