Need help removing my axel
Old Jun 10, 2002 | 12:42 PM
special's Avatar
I lossened the 3 allen screws and took loose the lock nut.Now what ?
Old Jun 10, 2002 | 01:41 PM
briansgi's Avatar
Special, I have not done my C'dale but it's probably similiar to my R. You of course need to remove your wheels, and the hubs. Next remove your brake caliper and brake rotor. Remove the 4 bolts at the very end of your swingarm, this is what holds in place the bearing carrier.
I'm not sure how the C'dale axle nut works but if it's like the R's, once you back it off, it will expose a c-ring. That c-ring is what the nut backs up against, at least that's how the R axle nut works. You then can remove the slider plate that goes between the brake rotor and the swingarm. Then the axle slides out along with the bearing carrier to the right, the sprocket and it's housing remains on the axle. Again, this is how the R's axle works and it looks like the C'dale is the same only *** backwards!!
Old Jun 10, 2002 | 01:50 PM
Alaska400EX's Avatar
I pulled my axle off through the sprocket hub side. JIM
Old Jun 10, 2002 | 03:00 PM
special's Avatar
I have the lock nut off there is about 1/4 inch play in the axel from side to side.On the axel there is a spine in the center witch holdes the sprocket hub on one side and the threads on the other for the lock nut.Both the threads and the sprocket hub are tight against the ring clips,How do I back eather one off so the ring can come out?
Should the threads slide on the spine given the slack to remove the
clip?
I hope this makes since I am not so good with explaning things,But really need help.My new axel is on the way.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 10, 2002 | 03:09 PM
I will try to type up a better explanation for you, but it came off real easy. Where are you getting your axle? What type are you getting? The reason I ask is because I had to cancel an order with on dealer today to order my LSR from K&K ATV. The dealer I cancelled couldn't be sure of when he could get them, while K&K ATV had them in stock for me. 369.00.........JIM
Old Jun 10, 2002 | 03:16 PM
There will be nothing holding you up once you get the threads to slide off the splines, but this was a pain for me at first. I did not take off my sprocket hub or the retaining ring holding it in place. I pulled the axle through on the sprocket hub side. Slide the threads off the splines, use the force, LUKE.......JIM
Old Jun 10, 2002 | 03:23 PM
Those half circle clips hold on the thread part that sits on the spline area. Sorry for the confusion, had to sit and think it through, took it off over a week ago. Just know that you have to get to those 2 half circle clips that hold the threaded piece in place on the splines. JIM
Old Jun 10, 2002 | 05:08 PM
briansgi's Avatar
Once you remove those c-clips off the axle, that axle nut then should slide off the axle, this is how it works on the R's axle setup.
Old Jun 10, 2002 | 06:05 PM
special's Avatar
Thanks guys.Im going to try to get the threads to slide away from the ring clip.I didnt want to use force on it if it was not suposed to move.
Old Jun 10, 2002 | 11:08 PM
Mxracer98's Avatar
That snap ring is a b*tch to get to took a little force but you can get it.
