New here - Need some help.
Old Jun 10, 2002 | 06:40 PM
Matt1970's Avatar
Wanna first say I love this board. After my neighbor got sick of me always beating up his Trailboss 250, I decided to buy my own. I got an Explorer 250 4x4 and I love it. I know most people go for the 500's and up, but I am a smaller guy (170lbs)and it has all the power I need. I have a pulling problem in the front end and I have come to find out that it may be common with Polaris. So much so I have heard that in the 700's they have fixed the problem. It pulls after backing up in AWD and with the override button enguaged. My first question, is this a fixable problem that Polaris knows about ? My second problem is that it seems to really bogg down when going through water more than 1 ft deep. My best conclusion is that because there is water hitting the hot spots, there must be steam choking the engine. It seems the engine will contine to bogg and sputter till it has burned the steam off. I don't think it's a tuning problem since the enging seems to have alot of excelleration and power, but I wouldn't think this would even happen. So my second question, is this common, is it a tuning problem or what ?? I am running 93 octain and think my next tank will be 89 and see how that does.
Matt
Matt
Old Jun 10, 2002 | 06:48 PM
bbertram's Avatar
Not sure on your pulling problem but I think I can answer your water problem. Imagine how much power it takes to drive fast through 1 foot of water. It takes allot !!! You might just be powering out until it revs enough to the point where there is enough power to get you going faster. You need more bottom end power, you need torque. Even my 500i bogs down in water and mud but as soon as it revs up some, the power comes on and your cruising. Thats my experience with water and mud anyways.
Old Jun 10, 2002 | 07:02 PM
Matt1970's Avatar
I was thinking that too, but a couple things led me away from that conclusion. 1)It sometimes won't do it in even deeper water. 2) When it does do it, I will sometimes come to a complete stop and it will take a good ten seconds for it to recover.
Matt
P.S. It is still under warranty.
Old Jun 11, 2002 | 09:17 AM
bbertram's Avatar
In your case something is wrong then.
Old Jun 11, 2002 | 09:39 AM
garyc660R's Avatar
Welcome Matt!
I would check my electrical connections and make sure no raw wires are exposed.
Old Jun 11, 2002 | 11:39 AM
Matt1970's Avatar
Thanks. I was reading some other posts and found Mike Chero had the same problem. His was a bad seal on his spark coil. I will check it out this evening.
Matt
Old Jun 13, 2002 | 05:16 PM
BUBASCRAMBLER's Avatar
MATT1970
How does your 250 Explorer compare to the Trailboss 250(TRAILBLAZER), I have always wondered.
Our Trailblazer 250 seems very underpowered and I can not Imagine it connected to a 4x4 system.
Old Jun 13, 2002 | 07:00 PM
Matt1970's Avatar
I like it. I know it's the lowest on the list for power, but it will climb any hill till it flips over and has enough top end speed for me. I havent clocked it, but I imagine it above 40MPH.
Matt
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
