Which should I buy?
Old Jun 18, 2002 | 01:08 PM
jeffman's Avatar
Which should I get for looks and/or performance?
-Nacs Headlight covers ($15)
-Nacs Parking Brake Block-Off ($12)
-Crossbar Pad with a Rebel Flag on it ($8)
Money is an issue too, its kinda tight right now!
Also, about the Nacs PB Block-Off, when I take my PB off will I have to bleed the brakes, add any fluid, or do I just unscrew it and put the Block-Off plate on there?
Thanks!
Old Jun 18, 2002 | 01:53 PM
250trailblazerkid's Avatar
get the nacs headlight covers.
Old Jun 18, 2002 | 05:03 PM
Quadfather's Avatar
Save it for gas. Sounds like money is pretty tight to be worrying about how to spend $12.
Old Jun 18, 2002 | 05:17 PM
jeffman's Avatar
I dont buy my gas! Besides I have plenty right now. Im thinking about the parking brake block off, thats what I might get...
Anybody know if I take that screw out of the PB from the caliper if I will have to add some fluid, will fluid come out, will I have to bleed the brakes, or do I just take it out and put the cap on???
Old Jun 18, 2002 | 11:09 PM
Quadfather's Avatar
You just take the two bolts out, put a layer of grease on the PB block off, take the cable out of the perch, and twist the two wires together, and put some electrical tape on them.
Another thing, unless you don't mind the spare parts on the perch rattling around, you will either need a new clutch perch and lever, or zip tie them to keep them from rattling.
