Very impressed!
Old Jun 20, 2002 | 01:57 PM
MadBaja819's Avatar
This is for anyone who might be looking to buy a Dynojet kit in the near future. I would highly suggest you order it directly from Dynojet. It is 5 dollars cheaper than Ron Woods, regular UPS is free, 3 day is only an extra 2 bucks and 2nd day air is only an extra 5 bucks and if you really must have it, 1 day air is an additional 15 bucks, a very good deal. Also their customer support has been great and very helpful and you don't have to worry about them being out of stock.
Old Jun 20, 2002 | 02:09 PM
Rockey's Avatar
What size are the jets that come with the kit? What all is included in the kit?
Old Jun 20, 2002 | 02:17 PM
MadBaja819's Avatar
Well the kit will be here tomorrow, so I do not knwo the size of the jets, I kwno it atleast goes up to 195. You could ask Hightower for the exact size of all the jets. The kit comes with a needle, spring, spacers, main jets and a couple other little things. Hope this helps, J.D.
Old Jun 20, 2002 | 02:34 PM
biggerisbetter's Avatar
I also bought my Jetkit from DynoJet, (Stage3) and it came with needle,an extra spring,jets(170,175,180,180,190,195,and 200). I am running the 195 jet, with a carbmount filter and clip pos. on the 3 Notch from the top.
Biggerisbetter.
Old Jun 20, 2002 | 05:56 PM
Hightower's Avatar
I like the performance if the needle so well, I'm getting a kit for my Arctic Cat!
Old Jun 22, 2002 | 08:09 PM
MadBaja819's Avatar
Hightower, I believe your running the 195 main and the clip in the 3rd position down, but I was wondering what you were running the fuel mixture screw on.
Old Jun 22, 2002 | 09:28 PM
Hightower's Avatar
Not exactly sure how many turns out it is. Here's my method (for the stock DS carb):
Turn screw in while bike is running at correct idle rpm, until the motor begins to bog and slow down. Then begin to turn outward , while counting every half turn, until it begins to bog again. Set the screw exactly halfway between the two points of bogging. You'll probably end up being around 2-1/2 to 3 turns out. Most manuals say set for best idle, but you can turn it a couple whole turns with little to no effect, so I like this sure fired way of setting it as close to perfect as can be without elaborate equipment. Whenever changes are made to air flow or jetting, I always reset this idle mixture screw afterwards.
Also, I fine tuned my jetting right after installing my new Yoshimura pipe at Little Sahara, OK earlier this year. Now, back here in Indiana - in the heat of this summer we're now having too - I'm feeling a little lean, and my plug has lightened up. I think I need to richen, so my next ride I plan on doing a little filter taping, and feeling out the 4th groove and 200 main. When I first put on the Yoshi, I started tuning and thought I was gonna need the 200, and then we went to OK where I finished tuning I ended up with the 195. Now that I'm back here I think I need the 200 after all.
Old Jun 22, 2002 | 10:08 PM
wshrdskin's Avatar
Rocky,
You can see the contents of what is in the kit and the recomendations for altiudes at www.dynojet.com. Click on dynojet kits once there.
Mar 21, 2016 06:30 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Riding Gear
Sep 15, 2015 02:59 AM
merryman
Sep 6, 2015 10:20 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
