throttle conversion kit for warrior
Old Jun 22, 2002 | 05:12 PM
dustin1207's Avatar
dose anyone have the throttle conversion kit on there warrior??? If so, do u like it or is it a waste? cuz i have riden a shee with the throttle converted and i liked it. i grew up riding dirtbikes so im just wonderin what all of u think??
thanks
Old Jun 22, 2002 | 06:43 PM
95wolv's Avatar
I assume you mean a twist throttle conversion,and it is real simple to install, just replace the right grip and use the provided throttle cable. If you grew up on bikes, you will have no problem with it,you are more used to the operation of a twist to begin with,and using your whole hand on the throttle is easier than just your thumb.For every rider, it just comes down to personal preference,use what ever works best for you.
Old Jun 22, 2002 | 07:14 PM
perrya's Avatar
also concider the type of riding you are going to do.
If you are going to race you will probably want the twist, but if you are going to be doin a lot of mudding or end up in off camber situations you are going to need the full use of both handle bars.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
