need help with scrambler 500 2x4
Old Jun 26, 2002 | 12:19 PM
jojr69's Avatar
the bike is cutting out at half to full throttle.the bike is piped and jetted,i switch carbs and the problem was still there.unhooked the reverse overide from the coil and that hasn't helped either.what sucks is it doesn't happen every time i ride it.the dealer says they can't tell me what's wrong if it's not broke. i also took fuel pump apart and it look good.
Old Jun 26, 2002 | 01:20 PM
jtrundle's Avatar
sounds to me like you need to rejet your carb. Check your plug and see what it looks like.
Old Jun 26, 2002 | 02:03 PM
BarelyLegal's Avatar
Is your air filter clean? Read your plug. Check the plug wire to ensure it's healthy.
How old is the fuel? Is your fuel valve on all the way? You changed carbs??? hmmmm
What is your plug gap? Test your coil.
When you changed carbs did you use the same jet size?
What are your mods? I used to have a Scrambler 500.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
