Need some parts
Old Jul 2, 2002 | 04:16 PM
crq350x's Avatar
Well my timing chain broke and so I need a new cam, cam sproket, and timing chain. Where is the best place to buy the parts i need on the internet. And there is no way I am buying from the dealer. They want $400
Thanks Colin
Old Jul 19, 2002 | 07:52 PM
Hightower's Avatar
The back of Dirtwheels is loaded with salvage yards that part out wrecked bikes. Look around there, make some phone calls.
Old Jul 19, 2002 | 11:04 PM
kciH's Avatar
Cam chain $94.05
Cam sprocker $26.60
camshaft $159.60
$280.25
partsfish.com-online parts fiche. It won't give you part numbers to shop with though.
bikebandit.com also has these but the price is slightly higher.
www.webcamshafts.com also has some cams that are cheaper and higher performance, but the savings will likely be minimized because you will probably need new valve springs to run some of them. They have 4 different grinds and the base one that improves overall performance works with stock springs.
I hope this helps. I wouldn't use used camshafts unless they where verified to be within spec before you bought them. These motors will shell out cams and heads if the oil is not changed regularly.
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
