question for my sport?
Old Jul 3, 2002 | 11:22 PM
polaris400sport's Avatar
I have a sport that has the same set up as the one below but it has a HPD trail pipe instead, now I raced a piped LT 250 And I won for 30 to 40 feet, then he was ahead about a length in mid range and then I slowly got him in top end, Now I should beat on him so does anyone know what I could do.???please respond.
Old Jul 4, 2002 | 12:39 AM
modquad's Avatar
Have you changed the gearing? That really makes a difference. Lots of people are running the 30 tooth rear. My 99 had a 36 rear stock, just changing to the 34 made quite the difference. The 30 is on it's way for the drags.
Ken
Old Jul 4, 2002 | 01:12 AM
Ronnnnn's Avatar
Why do you think you should beat on him, take into consideration the weight difference, if the LT250R is slightly built then any advantage you have is gone because you weigh so much more.
Old Jul 6, 2002 | 04:31 PM
scramblered's Avatar
clean yours clutch and make sure the belt deflection is ok,maybe a little side pressure on the secondary will help to get a better top end...with those mods i suggest you the 13-30 gearing,wich will give you a great snap at top end will increase from maybe 5 to 10 mph,i got this result on mine,
i run this gearing for 2 months already and i can say it help a lot the 380 2 stroke to get more strong top/end acceleration,good lucks.
cornermike
Sep 10, 2015 08:30 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
Sep 1, 2015 11:59 PM
