400EX spark EVERY or EVERY OTHER rev?
Old Mar 13, 2000 | 11:50 PM
MadDogg's Avatar
I installed a digital hourmeter/rpm gauge to my 400EX. Problem is the rpm is off by a factor of 2. Instead of 1300 rpm I get 2600 rpm at idle. Can the 400EX engine spark every revolution? Sounds crazy but I can't explain it. Please post if you know the answer.
Old Mar 14, 2000 | 12:13 AM
C&S's Avatar
C&S
yes,the 400ex sparks on every revolution .I am doing some research on finding a tach for atvs that read the right timeing. I will post what I find .
Old Mar 14, 2000 | 01:15 AM
MadDogg's Avatar
If this is true, a 2-cycle RPM gauge do the trick. What is Honda's reason to spark every rev?... emissions or performance? Does anybody else do this on 4-cycles?
Old Mar 14, 2000 | 01:46 AM
C&S's Avatar
C&S
all 4 strokes do this . they have a pick up coil by the flywheel that receives a signal on every rotation . they are called the fireing spark and the dead fireing spark.
Old Mar 14, 2000 | 01:25 PM
JRM's Avatar
JRM
None of my bikes do it. 91' XR250, 96' XR400, 86' 200SX..they all read right. I have the tiny tach model 4962nr* made for single cylinder 4 stokes. it does read wrong when the rev limiter kicks in.. goes from 9,000 to 5,000 RPM
Joe
Old Mar 14, 2000 | 05:29 PM
conway400's Avatar
Where did you guys get your tachs? What model? How hard was it to install? Thanks!
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Huntingdeer
Aug 23, 2015 12:06 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
