Help with rusty gas tank
Old Mar 15, 2000 | 11:34 PM
bigmanm's Avatar
I have a gas tank with some rust on the inside. and it has some holes in it. I would like to fix this one. How should i fix the holes. Solder them, bras it? Or is jb weld an alternative that will hold up.. What should i do about the rust on the inside.
Old Mar 15, 2000 | 11:43 PM
RangerSX's Avatar
you should just have the holes welded shut, and try some strong acid to clean it up, well that should work, see ya!!
Old Mar 15, 2000 | 11:48 PM
JRM's Avatar
JRM
I never have found a good way of cleaning one.. a friend said to use rocks and shake it up, but one spark and i got a bomb on my hands.. cant weld either. I have found the cause though.. our new ethonal fuel holds water in it and rusts metal tanks fast..if you see a sticker on the pump where you fuel up saying it has Ethonal id switch brands
Joe
Old Mar 16, 2000 | 12:39 AM
aczr2k's Avatar
Buy a gas tank renewal kit by a company like Eastwood. It is a few step process with different chemicals that etches, and then seals(as long as the holes aren't real big) with another chemical. Harley riders have been using the similiar process for years. I think their address is Eastwoodcompany.com. I am sure other companies make the same product, but this is the one that I have been around. Good luck!
Old Mar 16, 2000 | 12:45 AM
2000400EXinLA's Avatar
I have done this a hundred times, buy some Muratic acid from a local pool store. Put it in and shake it up real good, if it keeps coming out yellow that means it is still getting rust out, do this until it is relatively clean. Next clean the paint off from around the hole, and put some JB weld on it. We do it all the time where I work and have never had one fail when done right.
Old Mar 16, 2000 | 11:05 AM
exlax250x's Avatar
i had min fixed by a friend he braised the holes then he bought a gas tank renue kit and it lined my hole with a plastic like substance worked great i havent had a problem with it yet and its been almost a year
Old Mar 16, 2000 | 11:13 AM
bigmanm's Avatar
I think I am going to try the muratic acid then weld or solder the holes shut. I think they would be to big two fill with the gas tank renewal kit
Old Mar 16, 2000 | 01:55 PM
hondatrx300ex's Avatar
I think best thing would be to put a new plastic tank on it. All your problems would be solved. later
Old Mar 16, 2000 | 04:46 PM
bigmanm's Avatar
where could i get one of those.
Old Mar 16, 2000 | 06:46 PM
86Honda200SX's Avatar
What type of quad do you have this problem with?Clarke Manufacturing makes the take for the really old Honda's (ATC70-200SX) I've looked the price up for my SX and I think it was $120. ITP also makes a tank for the play quads.I'm not sure about the price.
