350X Wheels and Paddles, what size should I run??
I am pretty new to the bigger ATCs and just got a 350X. I want to get a decent set of wheels and paddles, but have no idea what bolt pattern, wheel width or paddle size to get. Can anyone offer some advice?
Thanks,
Dean
Thanks,
Dean
I found a set of used 20x11-8 paddles, any ideas if these fit the stock wheels? I don't even know what size the stock wheels are, and if I should stay with the same size or go with wider/bigger.
Thanks for any help,
Dean
Dean
those will fit on stock rims im sure the lug pattern is 4x110 as far as your chain clickin or not rolling free.. a buddy has 4 350x's and it seemed every time his clulch didnt feel right or it didnt roll right we found the frame cracked..same place on 3 different frames if your sitting on your bike next to your left calf behind the plastic.. good luck... those 350's are a fun ride
I see that alot of people run the 20 X 11 X 10s, is there any reason why those would be better?
I'll check on the cracked frame, but this definately appears to be something connected directly to the front sprocket or in the chain. I checked to make sure that the sprocket itself was tight, and the only other things I can think is that the chain is too dry or there is a problem inside the transmission. I'll drain the oil to change the filter tonight or tomorrow, and will look for any signs of failure (metal chunks, etc.).
Thanks,
Dean
Thanks,
Dean
1986Vmax540
Jul 9, 2021 09:53 PM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
