KandN filters
Old Jul 24, 2002 | 01:42 AM
cals400ex's Avatar
did anyone see a gain in power with just a KandN filter with jets. if so, where did you see the power gains at(low, mid, and/or high end). finally, did you prove these gains by racing someone or dynoing the bike? thanks for the help
Old Jul 24, 2002 | 12:25 PM
YZGUY's Avatar
When I put the K&N on (and an exhaust system), I lost low end but gained mid and high end. Later I put on an Edelbrock carb, and got even more mid and high end (high end is furious!), but the low end never came back. I think I lost low end because there is just to much air for the stock motor. I think an increase in compression is needed to get the low end back.
Old Jul 24, 2002 | 12:53 PM
gaff's Avatar
With a K&N and jetting you will notice better throttle response and power every where. The stock air filter of every quad is more restrictive. When installing a K&N you give the engine better breathing capabillities. Wich require some jetting. It will give the over all performance a better shot.
yzguy,
More than likely your pipe selection took your bottom end away. Pipes are made different, some are overall some are top, some are mid, and I believe the DMC is the only bottom one out there for the EX.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
