Need help for my pipe on the C-Dale.
Old Jul 24, 2002 | 05:49 PM
Sandgod's Avatar
I can't get any socket to fit the stock headpipe bolts where it goes into the cylinder. They look impossible to get to. Do I have to take the tank off?? Any help is appreciated. Thanks in advance....
Old Jul 24, 2002 | 06:52 PM
MikeXCR's Avatar
Sandgod, Take your gas tank out and it helps to remove the top bolt of your rear shock and move the shock back out of the way. A 12 point 1/4 inch drive 8mm or 5/16 socket works good for removeing the nuts that hold the pipe on. Good luck! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 24, 2002 | 10:02 PM
Sandgod's Avatar
Yeah it worked, Thank You!! Must be a 12 point though of either an 8mm or 5/16. Didn't pull the tank. I had a wobbly w/ four different lenths of 1/4 inch extensions to get the various angles it needed to get if off. My wife put the washers and bolts back on w/ her tiny little fingers and I just messed w/ them for an hour to catch the various angles to tighten them up. Pain in the ****!!!!
Old Jul 24, 2002 | 10:18 PM
briansgi's Avatar
Now you know why that rear oil filter won't get cleaned/checked very often!![img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 25, 2002 | 12:10 PM
mxrookie's Avatar
Thata what i would have tried several woobly extensions or worst case senairo would have been pull the tank out . good to have the wife around with the little fingers to help ...
Niels
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
