Cool oil?
Old Jul 31, 2002 | 10:11 AM
RaptorDownUnder's Avatar
Anyone running an oil cooler on their raptor? If so, what type and where did you mount it? Is it worthwhile?
I have found several posts for a warrior oil cooler and I know four stroke tech makes one for the warrior, but I cannot find anyone that has one on their raptor.
Thanks
Old Jul 31, 2002 | 01:04 PM
CTRaptor's Avatar
The raptor doesn't need an oil cooler, because it is already liquid cooled. Oil coolers are mainly for air cooled bikes.
Old Jul 31, 2002 | 04:49 PM
THEMOOSE's Avatar
If you think it's running hot you can get a Pingrys oil tank, It holds an extra quart & will make it run cooler.
Old Jul 31, 2002 | 11:55 PM
FISHER1648's Avatar
That super-duper coolant mentioned a week ago might help ? I forget the mfg. name.
Old Aug 1, 2002 | 12:10 AM
CTRaptor's Avatar
Engine Ice but it's expensive.
Old Aug 1, 2002 | 12:20 AM
14mins's Avatar
At the quad bash june 29th 1 raptor had a oil cooler mounted in front of the radator. I think pingry's would be the way to go. I like the extra quart. We ride hard and change the oil a lot. I use ac delco 2057 oil filters. A lot cheaper
Old Aug 1, 2002 | 06:47 AM
I bought a trans cooler that will fit nicely in front of the radiator. I think I will give it a try, cant hurt I guess. I think I will run the oil line from the top of the oil tank to the cooler and then from the cooler to the top of the tank. I am going to check the engine temp before and after with a heat gun and see if it makes any difference.
See ya
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
