Wont start when hot and fan not going full speed?
Old Aug 5, 2002 | 05:22 PM
mxzxracin's Avatar
I was out riding and my ds just stopped running, Then I pushed the start button and nothing happened, I pushed it a few more times and it finally started.
Then I went riding the next day and I shut it off after a while and I noticed that the fan was not turning at full speed, and I pushed the start button and nothing happened, I let it sit for a while then pushed the button again and it started.
Anyone have any idea what it could be? I think the fan might have a bad bearing. What are all the after market cooling systems? I made my own radiator scopes.
Thanks
Nick
Old Aug 5, 2002 | 07:07 PM
DSRide's Avatar
What battery are you using? Every electrical problem I have had has been the Battery,Loose connections or a bad battery. Do not buy a Power Source battery. Power Source are junk and do not work with the Bomb. (found out after buying 3 of them)
Old Aug 5, 2002 | 07:11 PM
mxzxracin's Avatar
I checked the wires going to the battery that is the first thing I thought of, and I dont think the battery is bad because I tried to charge it and it was the same. And the lights and are bright and when it does start it turns over just fine.
Old Aug 5, 2002 | 08:36 PM
QUADMAN650's Avatar
Hey man remember the other day when you said nothing is wrong with your fan. Well now there is your fan is going out bombardier sells one for 100.00 but talk to 99x on the forum and he may know of one that you can order cheaper
Old Aug 7, 2002 | 02:32 PM
mxzxracin's Avatar
Well, I took the fan apart today and one of the wires inside the fan came unconnected so I reconnected it back in place put the fan back together and now it works great.
Still dont know if the starting is screwed up, have not taken it for a ride
MikeyBoyesq
Nov 27, 2020 02:44 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
