valve adjustments for 660 grizz?
Old Aug 6, 2002 | 11:30 AM
HELLFISH's Avatar
Has anyone had their valve's adjusted or have done it on their own know if they are shim type or lock-nut rocker(auto)style,i have heard that every 1000mi or so you need to check or make adjustments on the valve's is this true my dealer said nothing bout this?
Old Aug 6, 2002 | 01:02 PM
mich660griz's Avatar
lol. i hope you were joking, lol. the valves,( rocker style) need to be adjusted on the grizzly at least every 100 hours. i do mine every 20 or 25 hours. the 3 intake are always tight for me, along with almost everyone else. doing it is pritty streight foward. get a manual, and follow it step by step, and it will take about 2 hours the first time. i now have it down to less than 2 hours. things you have to remove to do them.
1.) front rack.
2.) gas tank cover.
3.) white plastic under gas tank.
4.) gas tank itself.
5.) manual puller cover.
6.) manual pull start rope itsself.
7.) side panel behind right front wheel, ( little black panel with 2 10 mm bolts.)
8.) right front tire.
from there, just follow the manual, and its a breeze.
good luck
my pictures
Old Aug 6, 2002 | 01:24 PM
HELLFISH's Avatar
Thanks alot!,maybe a switch to stiffer dual springs might cure this problem.
Old Aug 6, 2002 | 07:11 PM
2002grizzly660's Avatar
I just got done doing mine today for the first time, it took me about 1 hour to do it. They were done at 20hours, and now at 160 hours they were very very tight.
Doing them is very easy to do, just have a feeler gauge set, and you'll be allset.
Steve
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
