grinding noise p650
Old Aug 7, 2002 | 05:04 PM
th41004's Avatar
I have a p650 with around 900 miles on it. Now when I make a turn when there is pressure on the right front tire it makes a grinding noise. I jacked the quad up and couldnt get it to make a sound. Everything feels tight. Anyone have any ideas????
Old Aug 7, 2002 | 05:08 PM
Parker650's Avatar
Bad CV Joint?
Old Aug 7, 2002 | 05:26 PM
th41004's Avatar
I dont know the boot isnt leaking any.
Old Aug 7, 2002 | 06:06 PM
ConMan's Avatar
I would check the hub assembly (bearings) and inner and outer cv joints. This is about the only thing that can make noise (unless you have a rock in one of your brake rotor holes like I did) Check all of these things out, if nothing gives, then you should be good to go.
flyin-lowe
Dec 1, 2017 03:18 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
