Parking Brake Blockoff.
Old Aug 9, 2002 | 12:36 AM
Zombie66or's Avatar
I was wondering if you have to bleed the Brake system after taking the parking brake off? Then what do you do with the brake line going to the clutch lever? Thanks Guys!
Old Aug 9, 2002 | 01:09 AM
KNOWSALOT's Avatar
The Facility
No bleeding required because you aren't tapping into the hydraulic portion of the caliper.
Just remove the cable from the perch and toss it. Then, your next mod would be to put an aftermarket "quick adjust" clutch perch and lever assembly.
All of them are designed off of the same leverage ratio that comes stock on the Honda CR. Another Honda patent that the aftermarket is abble to get around by installing a different bushing in the bolt collar.....smart guys indeed.
Old Aug 9, 2002 | 11:23 AM
Zombie66or's Avatar
Thank you very much KnowsAlot! I will be attempting this!!!!!! I'm goin in.
Wish me luck!
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
