400EX countershaft sprocket question?
Old Mar 19, 2000 | 02:18 AM
norm440EX's Avatar
I just changed my 16 tooth countershaft sprocket back to 15 tooth because I am going on a dune trip, when I put it on and tightened it down, I noticed a very small amount of sideplay in the sprocket. Its been a while since I changed to the 16 tooth, so I don't remember if there was sideplay in it also. Is this normal or did I put it on wrong?
Old Mar 19, 2000 | 07:10 AM
Mike300EX-99's Avatar
My 300EX has play, this is normal.
Old Mar 19, 2000 | 12:20 PM
Y2K300EX's Avatar
How in the world do I get my front sprocket off my 300ex. I can't get it off. Please help. Also how do I keep the case saver and still put on a 14 tooth sprocket.
Old Mar 19, 2000 | 03:42 PM
norm440EX's Avatar
You have to loosen your chain adjustment up and then slide the sprocket off and work it out of the chain links. when I put the 16 tooth on my 400EX I had to remove the case saver and put some spacers on the bolts so the sprocket cover fit right, I haven't found a case saver for that size sprocket, it's probably a similar issue on the 300EX.
John Reed
Sep 9, 2015 03:46 AM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
