Rev Limiter
Old Aug 17, 2002 | 08:56 PM
ConMan's Avatar
Just a question, but if I ever decide to open the ol girl up, the rev limiter will keep the engine rpm's below damage level correct?
(I have a local friend who can always repair body damage and most chassis damage, but engine damage is a different story.)
Old Aug 17, 2002 | 10:45 PM
alltoys's Avatar
Yes there is rev limiter as such but any sustained high revs is not good for any machine even race motors. Any pro racer will tell you motors are not designed to rev passed a certain point even if you wanted it to. Only because of valve float and some other factors but if at that point you decide to keep it there trust me it will fail. It doesn't hurt any engine to attain the highest rev limit but drop it down imediately there after. Your power band is always approximately 2000 rpm above idle and 1000 rpm below upper rev limit. Once you have acheived upper power band rpm your power will actually drop off considerably. Even 2 strokes will eventually lose power only because of mechanical inherant defalts. The only engines that seem to defy logic are turbines and if you remember the old Wankle engine. Again it doesn't hurt to find the upper rev limit just make sure you drop it down reasonably soon!!!!
Old Aug 18, 2002 | 12:36 AM
mastrblastr's Avatar
Hi Alltoys. As you and I have already discussed, the motor in the 650 could handle a LOT more redline rpm than it currently has. 1bearman's CDI box is gonna prove that I hope!!! 1bearman, any comments?
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
