oil cooler
Old Aug 18, 2002 | 12:44 AM
HondaEXtreme01's Avatar
how hard is it to put an oil cooler on a 300ex? is it worth it? where can i find one online?
Old Aug 18, 2002 | 12:55 AM
smitty911's Avatar
Four stroke tech has one for around $100. You will need to drill and tap a couple of holes.
Smitty
Old Aug 18, 2002 | 10:40 AM
Need4Speed's Avatar
You dont have to drill and tap anything with the FST kit. There's an oil line that goes from the crankcase to the valve cover. You cut the line about 2 inches from the valve cover flip it around so the cut end points towards the front of the quad. You zip strip the cooler on the front of the quad and hook up your hoses, it's simple.
Old Aug 18, 2002 | 02:13 PM
smitty911's Avatar
My mistake, I could have sworn I read in the review that the oil line going into the top at the valves had to be tapped.
Smitty
Old Aug 18, 2002 | 02:58 PM
where did you get your cooler from? how much does it help?
Old Aug 20, 2002 | 12:06 PM
AlkyBurninX's Avatar
My 250X has a Jagg oil cooler. I think they are available through a Parts Unlimited dealer. For the jagg cooler, your replace the oil filter cover with a billet piece that is supplied. Then you zip tie the cooler on the front frame, and run hoses. The coolers really help. I have a problem on Alky though. Since Alky doesn't generate a lot of heat anyway, the cooler actually drops the temp to dangerous levels on cool days.
STLyamwar
Jul 25, 2020 04:44 AM
ronnierhino06
Nov 9, 2015 12:56 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
blessedn09
Aug 9, 2015 03:07 AM
metal249
Jul 24, 2015 01:00 PM
