Milled head on my Banshee question
Old Aug 20, 2002 | 10:23 PM
My99Banshee's Avatar
I want to have the head on my Banshee milled to get more low end power comparable to a Coolhead with 22cc or 21cc domes, I just cant see spending $280.00 on a coolhead when i can have the stock one milled cheap! My question is how much should I have it milled?
Old Aug 20, 2002 | 10:53 PM
bansheeboy93's Avatar
i have seen people mill 35 thousants and 40 thous. mine is milled 35
Old Aug 20, 2002 | 11:57 PM
Thanks for the info Did you notice a difference in low end power? and how much did it cost?
Old Aug 21, 2002 | 12:43 AM
Ward660R's Avatar
Can you go the same amount on a Blaster?
Old Aug 21, 2002 | 09:14 AM
garyc660R's Avatar
For pump gas, .030 is a safe number on your Banshee. THis is an excellent and cheap mod. If you are not whether this can be done properly in your area....send it off. I sent my last stock head too Majic Racing in Michigan.
Old Aug 21, 2002 | 11:34 AM
AlkyBurninX's Avatar
You can gain even more useable power if you play with the dome angle. This is almost as important as adding compression. If they change the angle, the amount that is removed from the deck varies. FTZ cut mine.
Old Aug 21, 2002 | 05:11 PM
WyoDuner's Avatar
I recommend that you check your compression before and after you have your head milled. It's good to know how much of an increase you go and also you want to be sure the compression isn't too high.
Old Aug 21, 2002 | 09:07 PM
some,and about $30
Old Aug 21, 2002 | 11:14 PM
Ok thanks for the info.
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
