tires
Old Aug 22, 2002 | 01:06 AM
buckmaster149's Avatar
my timberwolf 250 has 22x10-10 tires on it now and i need new ones. i found some good 22x11-10 tires- will they fit on there?
Old Aug 22, 2002 | 01:10 AM
THEMOOSE's Avatar
I would thik that they will fit with no problems.
Just as long as the tires you have now don't have a clearance problem.
Old Aug 22, 2002 | 08:42 AM
buckwheat12's Avatar
The 22x11x10 will fit fine. You won't notice a difference. I replaced my stock tires with the Maxxis Sur Traks (22x11x10) back when I had my Timberwolf, and they worked great. The only real difference is most of the aftermarket tires are usually heavier than stock because they are usually higher ply (thickness) tires. The Maxxis Sur Trak were only two ply so they were lighter than most of the other aftermarket tires. You may want to keep that in mind when looking at tires.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
