who runs paddles on a 250ex, i have a question for you
Old Aug 22, 2002 | 12:32 PM
DPGRDI's Avatar
Im buying my wife a 250 ex for our rides at the dunes. i talked to a guy who owned one and he said they were not powerful enough for paddles, im going to put on 20" sand sharks V paddles, i think it will do just fine, if it does not ill regear on tooth down in the front, anyone have this setup, can you make it up most the dunes or what, i used to have a TRX200SX back in the day and it had plenty of power, the 250EX has got to be double what that old thing had.
opinions?
DPGRDI
Old Aug 22, 2002 | 12:38 PM
sickmojave's Avatar
good luck going one tooth down in the front. it's shaft drive[img]i/expressions/face-icon-small-happy.gif[/img]
biggin's Avatar
Isn't the 250ex a shaft drive?If so,that might be a project gearing it down.Good luck.
Old Aug 22, 2002 | 12:40 PM
biggin's Avatar
Sickmojave sorry about the repeat post,you must have posted a few seconds before me.
Old Aug 22, 2002 | 12:57 PM
DPGRDI's Avatar
Ok than guys, maybe i wont regear, ill just get a SHAFT REDUCTION, ha ha, well than ill stick with the stock gear ratio, so the question remains, any trouble spinnin 20" V paddles and making it up MOST of the Larger dunes????????????
DPGRDI
Old Aug 22, 2002 | 01:10 PM
atc86r's Avatar
we run them on 250ex. no problem. works great. skat trak hualers.
Old Aug 22, 2002 | 03:55 PM
YZGUY's Avatar
The 250 does ok in the dunes, but it is mostly ridden by light riders. We run 6-paddle Skat-Trak Edges in back, and Skat-Trak Mohawks in front. All are on ITP rims, which makes the bike about 3" wider in the rear and 2" in front. The bike has a K&N and FMF MegaMax II, so that helps in the power department. I always prefer the BUFFED DOWN sand tires because they are lighter, and you need all you can get in the sand.
Old Aug 22, 2002 | 04:20 PM
250EXcited's Avatar
I used 20" Sand Sharks on my 250EX and I could go anywhere at Little Sahara. Had to get a running start at the bigger dunes, but made it up with no problem.
Old Aug 22, 2002 | 09:38 PM
DPGRDI's Avatar
what is the offset for the wider ITP wheels, do you have to special order them or what, ?
DPGRDI
Old Aug 23, 2002 | 10:38 AM
ryanh250ex's Avatar
you could always get a big bore kit for the 250ex from powroll. their site is www.powroll.com. i dont have one (my 250ex is piped and jetted), but i've heard good things about the kit
