Stupid Question about Ohlins
Old Aug 23, 2002 | 10:29 PM
BlackBird1100XX's Avatar
I have a easy question to answer. I bought a 03 LE, Arvins fronts. The valving and oil section was on bottom, with the chrome shaft positioned up.
I bought retroZ's Ohlins fronts, and with the word Ohlins positioned where you can read it, thats upside down compared to the Arvins.
I mounted them with the word Ohlins where you can read it, chrome shaft side down, is that right, or does it matter? It looks like that would be the best dirt protection.
Thanks!
Old Aug 23, 2002 | 10:50 PM
JayBR's Avatar
I think you may have them upside down, the preload adjustment mechanism goes up top so the spring is on the bottom.
Old Aug 23, 2002 | 11:20 PM
daimon1054's Avatar
I am not sure if they are upside down or not but it make a ton of difference. You will be working the rebound valve and not the compression and vis versa. This could mess you up bad so I would go to the dealer and check it out before I ride.
Old Aug 23, 2002 | 11:44 PM
Ok, I guess I'll ask this then. On the Speed models (or cannibals with Ohlins), can you read the word "Ohlins", or is it upside down? That would be the answer. I'm not with my quad right now, so I'm not sure about the preload on top or bottom.
Old Aug 24, 2002 | 12:08 AM
4strokemadman's Avatar
The shafts go on the bottom. It should read Ohlins properly.
Old Aug 24, 2002 | 12:14 AM
Thanks 4strokemadman,
I figured and installed them that way, but the Arvins were opposite, so I wanted to make sure. Question answered!
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
