Need help wiring TRX300 to start in any gear......
Can anyone tell me the procedure to wire a TRX300 so it will start in any gear. I know there will be a grounding button to push, but that's OK. I wired the 400 Foreman and it works fine, but the same procedure doesn't seem to work on the 300. Thanks in advance.
I don't suppose it's the end of the world if I couldn't do so, but say for instance you hop on your bike and it's in 1st or 2nd gear you can just hit the starter and run. Or, let's say you're tooling along and you happen to bump your kill switch. If you're in 3rd or 4th gear it would really be nice to be able to just hit your starter and keep rolling. Otherwise you have to downshift to neutral, come to a stop before restarting your engine. If you and your buddy are playing tag that could be a real pain. Maybe it sounds petty, but I can think of several times I wish I'd had that ability.
JC
JC
well I too have thought about doing this to my atv and I am a tech at a Honda dealer and have had others want to be able to do this also. It is a saftey feature so keep that in mind what you need to know is that the wire need to ground to turn on the neutral light that's as much as I will tell you because like I say it is a saftey feature besides what fun would it be not to be able to play tag on ATV and not be able to reach over and turn off your kill switch making you have to shift back to neutral to restart.
Are you saying that you can't just pull in the clutch on this model? If not, it doesn't seem like a safety feature to me. I've stalled in some pretty bad spots that I wouldn't have time to find neutral. Ever been following someone to closely up a steep hill and they stall? I want them to be able to get started ASAP.
This makes about as much sense as not putting lights on kids quads. I run with my lights on in the day all the time just hoping to give another rider a better chance of seeing me if we are coming towards each other.
/NotuRaptor
/NotuRaptor
It should be as simple as unhooking the two wires that go into the whole clutch lever piece. . I did that to my buddy's 400ex and it worked great. . there is nothing to it. . it takes about 2 minutes . .good luck. . let me know if that works
well cluby, you just basically gave the thing away. You're worried about safety and you're playing tag on atv's?? All you need is a wiring diagram and real basic electric skills. If you can't figure out from there, maybe you shouldn't be trying it. Jeepr didn't do this, his info is wrong for this model.
