Anyone know anything about the DIAL A JET SYSTEM?
I saw this system in a mag and looks like a good idea for me. I guess you install the kit and it has a rotating **** with like 5 different settings to set your jets. Very easy so when you want to change your settings you dont have to open the bike up you just turn the ****... Anyone have this or any opions would be great im thinking of getting this for my Raptor.
You will need 2 kits,one for each carb on the Raptor,but,yes,it does make jetting adjustments quick and no dissassembly required. By supplying highly vaporized fuel to fill in the gaps in the fuel droplets,it balances out the air/fuel mix,giving better throttle response and power throughout the rpm range,and is completely automatic,adds more/less fuel depending on the engine load and vacuum signal coming from the carb.
Hardhitten-
The complete setup for the Raptor is right under $140.00. That's one dial per carb, plus 2 snorkel filters. It's a breeze to install, and it works great. Customer service and tech support was great. Lonn is the owner, and is more than happy to help you out. In fact, if you go with a k&n filter, full exhaust, remove flap from snorkel, you won't even have to rejet. Their system will fill in the lean spots. Additional mods to the airbox may require you to rejet. Anyway, I like the system, and I liked the way I was treated as a customer.
speedbuff
13
Nov 11, 2020 10:16 AM
jrooker6
Apr 23, 2016 07:36 PM
Oct 10, 2015 10:20 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
