Plastic Polishing?
Old Aug 29, 2002 | 05:25 PM
Rudedog's Avatar
I have an 1986 250R that I'm fixing up. Question, the gas tank has a white-ish oxidation that has built-up on it. Does anyone know how to get rid of it without loosing too much shine? Wet sand with 1200 sandpaper? Polising compound.... ?
Rude Dog
Old Aug 29, 2002 | 05:46 PM
mojave300ex's Avatar
First wet sand it with 400 paper, then with 1000. When you wipe the water off after you've sanded it, it will look scary WHITE. To get rid of that white, use 3M Machine polish, on an air/ buffer with a foam pad, cloth will get hot and turn your polish into glue, wipe all the polish off after you've buffed, and use some Turtle Wax Formula 2001, it's simmilar to armoral, wipe it on thick so you can see liquid on the surface of the plastic, and let it dry for 10 min, use a cloth rag, and wipe off the turtle wax with pressure on the cloth, and it will shine.
Old Aug 29, 2002 | 09:21 PM
LT500duner's Avatar
That's how I restored my Honda tanks, except I used a silicone based tire gloss. I normally wouldn't recommend using anything slick if I was going to ride it, but it worked well for storing tanks for future projects. If you've ever hit an errant mud/water hole and racked the nads on the handlebars you can see why slick stuff and water doesn't work that great for riding. ;-( Of course you're in CA, so it's probably not a big deal as it hardly rains here.
(And before I catch any crap for that from other posters I was up on the pegs in the rough stuff.)
There is a kit available that is supposed to be good, it's called plastic renew, it was in tested by one of the quad magazines.
I saw an ad for it in Dirt Wheels by a company called pc racing, www.pcracingusa.com in California. It's listed for 18.95 and they have good pictures of the process on the site.
Old Aug 29, 2002 | 11:49 PM
Plastic renew is great. But it only works for temperary time. Don't get gas on it, it will bubble. Bubbling in one spot will force you to compleatly start over on the piece that has one little bubble, because you can't just do one spot it will be shiny and the plastic around it won't. If you are a careful rider I would reccomend it, but if you do hard trail riding don't go near trees, yeah it will scratch right off. Sorta looks like painted plastic when finished.
Old Aug 30, 2002 | 03:02 AM
LT500duner's Avatar
So it's more like a clear coat? I thought it was more of a protectant, with their suggestion to smooth it out with steel wool. Wouldn't that remove it?
Old Sep 3, 2002 | 06:03 PM
Duneaddict's Avatar
Mop-n-glo!
Keeps the plastic pretty shiny for quite a while, and you probably already have it under the sink.
Old Sep 4, 2002 | 05:22 PM
Rudedog's Avatar
Thanks guys for all the help on this subject!!!!
Rude Dog
Old Sep 4, 2002 | 05:27 PM
dash's Avatar
remember "wax on .... wax off"
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Brandon400
Sep 5, 2015 08:44 PM
