Some more questions about the Cannondales.
Old Aug 31, 2002 | 05:05 PM
Kodiak01's Avatar
Now bare with me, I have alot of questions before I buy my Cannondale
1.How much Adjustability do the Front & Rear Shocks on the Cannibal have?
2.What Handlebar bend is on the Speed, Blaze, & Moto?
3.Whats the Wheel Offset on the Cannondale?
4.What kind of Mileage are you guys gettin, like in terms of hours?
5.Do the Cannibal & Speed have the reinfoced Swing-arms?
6.How do you suggest I care for the Foam AirFilter,& Does anyone make an Outerwear for it?
7.What are "Traction" Maps?
8.What map do you suggest for mostly Dump & Trail Riding?
9.Which Exhaust System do you suggest?
10.Whats up with the problem of getting Oil in the Airbox?
11.Ive heard alot of talk about the Fuel Filters, whats up those?
12.Do AC Propeg Nerfs work with the stock Heelgaurds?
13.Ive heard people say that its not good to let it idle for long, why?
14.How would I go about installing a on/off Switch for the Radiator Fan?
15.Is there a way to install a Neutral Light?
16.Whats the problem with the balljoints?
& Finally
17. How much is the rider trim?
Thanx for the answers, I know its alot of questions but I need to know.
Old Aug 31, 2002 | 05:27 PM
jbomb's Avatar
Just buy it, you will love it compared to the DS. I trade my DS in for the speed.
Old Aug 31, 2002 | 05:31 PM
Kodiak01's Avatar
Oh dont worry Im defenitaly gonna buy either a Speed or a Cannibal, just wanna be prepared when I get it.
Old Aug 31, 2002 | 11:11 PM
JayBR's Avatar
<< Now bare with me, I have alot of questions before I buy my Cannondale
1.How much Adjustability do the Front &amp; Rear Shocks on the Cannibal have?
2.What Handlebar bend is on the Speed, Blaze, &amp; Moto?
5.Do the Cannibal &amp; Speed have the reinfoced Swing-arms?
6.How do you suggest I care for the Foam AirFilter,&amp; Does anyone make an Outerwear for it?
7.What are &quot;Traction&quot; Maps?
8.What map do you suggest for mostly Dump &amp; Trail Riding?
&amp; Finally
I'll try a few, can't answer them all.
3. I believe 3-2 front, not sure on back.
4. Alot, haven't really timed it but I'm sure I can go along time. I rode 3 hours today and burned maybe 1/2 tank.
5. yes, I believe all produced since Jan or so. My Speed #24 does not.
6. I just use filter cleaner and foam filter oil. Not sure about the outerware.
7. Traction maps seem to not rev as quick on the 1st 1/4 to 1/3 throttle so you don't get so much wheel spin on takoff - more suited to trails as you can putt around easier.
8. For trails I like the Traction map, haven't tried the blaze map yet.
9. I run the HMF silencer, but I've heard some people like the Big Gun. Trinity is also supposed to have a full pipe out soon.
10. It was mostly cause by overfilling the oil or a clogged breather line. The line problem was addressed by a service bulletin and should be fixed on all new quads.
11. Fuel filter is no big deal, just change often and their only a couple bucks.
16. Balljoints don't have a seal on them so they are exposed and hard to keep grease in them. I heard there was a change with the 03's
Someone else will have to chime in on the others
Old Aug 31, 2002 | 11:16 PM
lt250r91's Avatar
Ok I'll try my best
Rear shocks is fully adjustable (preload, compression, &amp; Rebound0
Front shock you can only adjust preload.
When I race I get about 1 hour and 45 minutes on a tank. Trail Riding is around 4-6 hours pending on how much throddle is used. I ride with alot of slow pokes on utility quads (it sucks).
For trail riding I would reccomend the blaze mapping.
Right now HMF make the best pipe system (its loud).
The oil in air box problem is solved on the 03's. It was something to do with oil pressure and over fill (ite think).
The fuel filters are reccomended to be changed every 25 hours. I change mine every race when I change the fliuds. For 2.50 at Napa for the Wix 3011 filer it's worth doing instead of a having the filter plug up.
I have nerfs that where made by my dealership and I still have the healguards on so they should work with the AC nerfs.
The only reason I don't let mine Idle long is do to it heating up.
The fan kicks on and off when the temp reaches a certain point. I would add a switch let the computer do it's job, better than forgeting to turn it on and overheating the engine.
For the rider TRim check out GP controls Website: GP control.
Old Sep 1, 2002 | 01:26 AM
Derno24's Avatar
Ok here is my take as far as the filter goes just clean it every 5 hrs riding or like me after every time I ride. I ride for several hours at a pop.
As far as mileage is concerned you get what you get. Hammer the throttle like on a race and get little more than 2 hours. Ride the trails and get 4 -6 hours. This was already covered.
I run the HMF and I am very happy with it. I hear the trinity is good also.
The blaze map works well for the trails and such.
Also as far as idling too long don't sweat it. I had mine idiling for more than 30 mins in 90 plus weather and it is fine.
The rider trim I think for the basic setup is about $700
Old Sep 1, 2002 | 01:35 PM
jcv400ex's Avatar
Rear is compression and rebound adjustable, front Ohlins are only Compression. The front Arvins are non adjustable.
It's like a CR Bend. The new steering stem makes a good change. The top angles back with the stem instead of flatening off.
I believe it's +4 +1 on the fronts. It's wider than the 400ex offset.
I can easily get 2 hours on it in a Harescramble race. I think you could get about 50-60 miles out of a tank of gas.
The new swing arms are &quot;boxed&quot; in. They're very strong.
I'd order 2 more filters. This way you'll always have a clean one. I use the Honda foam filter oil and UNI cleaner. Put some oil in a baggy, drop the filter in it, work the oil through the filter, and ring out the extra. No one has an outerwear yet, UNI mfg's the current filter and has a contract with Cannondale to not sell them to the public for one year.
less throttle response down low so it doesn't spin as much
I like my Blaze map with the Big Gun exhaust. It does a good job for woods and trail riding.
I like the Big Gun. Good design and it stays together. The Full HMF kit seems to be a good pipe though.
Overfilling the oil and running the engine hard. There is a buliten to eliminate this though. THey have a new venting design.
There is a filter off of the back line out of the fuel tank. You need to replace them ever 5 hours. THey're $3.00 at Napa.
No, not as they sit. You'll need to do some modifications or order the Pro Pegs with the aluminum guards.
That goes with any fourstroke. It's for the cams. Too much idling results in pre-mature cam wear.
Really wouldnt want to do this. The computer is set to turn it on at a certain temp.
Not that I'm aware of
The new ones have a new design. Problem resolved. Now, the tierod ends need to be greased after or before every ride. They're wide open to the elements, and seem to get some wobble in them over time.
&amp; Finally
The system that mounts on your handlebars runs $1300 I believe. THere's more info on R&amp;S's website. www.rsperformance.net. I recommend you get the $300 GP Control software. THis will allow you to load fuel maps and check your idling. The Idling does drop over time.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
