k & N or Uni Filter???
Old Mar 22, 2000 | 06:23 PM
jtaylor's Avatar
I have a y2k Trailboss and was wondering what filter to put on. I drive mostly trails and go through some muddy conditions. Is one better than the other?
Old Mar 23, 2000 | 09:48 AM
monk01's Avatar
Hey jtaylor,
They both have purposes. I read that the Uni works better for sandy conditions. So if you ride sand or railroad tracks I would go Uni. K&N is said to be better for muddy conditions. So, it looks like you should go K&N. I hope I helped a little. I just wish I could remember where I read this. So I could have you go and check it out.
Old Mar 26, 2000 | 05:24 PM
Sburdman's Avatar
Go with the UNI, it is usually half the price. I would use "Competition Accessories" (1-800-543-3535) where they sell for under $20. I use to recommend Chaparal Motorsports but my latest experience with them left an extremely bad taste in my mouth.
Scott.
Old Mar 26, 2000 | 08:00 PM
scram4's Avatar
Mr. Taylor, I too have wondered what filter to by so I bought them both. I ride mostly in soft sand and dry conditions, when I used the K&N in this situation I had a trace of dust particles down in the rubber tube going to the carburator, not a good thing I thought! The K&N was oiled as per the directions in the box and to top it off I even had a outerware cover on the filter. I decided to try the UNI filter next. It is a two piece unit, the inner foam filter is a finer foam element than the outer foam element. This filter properly oiled has out-performed the K&N filter and without any reduced performance from my Scrambler 400. I use 30W engine oil on the UNI filter and clean it every other time I go out riding. I think you would be better off buying the UNI it doesn't cost as much as the K&N and it doesn't need special cleaner or oil as K&N does. Now I'm not knocking K&N I just don't think it works for my Scrambler for whatever reason. hope this sheds some light on the subject of airfliters for you. Ride safe!
Old Mar 27, 2000 | 10:46 AM
jtaylor's Avatar
Thanks for the info...I think I go with the UNI filter.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
