Tips on ramping.
Old Sep 3, 2002 | 12:50 AM
bandit390's Avatar
Ive done it a couple of times. Mostly about 3-4 feet(I just started) I seem to be doing alright, just waiting and working up to bigger. But then I let my friend jump a couple times and when he did he landing, kinda on top of the handle bars running along side it.( wish we had a video camera lol)
any tips?
Old Sep 3, 2002 | 07:58 AM
McFly's Avatar
TIP No1 as Wes Miller says "Keep the rubber side down"
or as I say "Keep the plastic side up"
Old Sep 3, 2002 | 10:16 PM
Turbo33's Avatar
Tip # 2 don't be in a hurry to go higher or farther.
Are you having fun?
Getting bit is NO FUN.
Old Sep 3, 2002 | 10:39 PM
iamchad2k5's Avatar
#3. dont try any tricks untill you can get major air. believe me, it sucks.
#4. depeding on the quad, you have to balance your weight. if the front is heavy, lean a little back. (this also depends on the jump)
if the back is heavy make sure to get up on the front end of the bike to keep the front down. and if landing to flat, you want to land a little on the rear tires.
Old Sep 4, 2002 | 06:18 AM
McFly's Avatar
Allways land on the gas, it will prevent you from bottoming out by compressing the rear shock as you land.
As you hit the lip of the jump, blimp the throttle, this will make the front end light. You always want to be front high, except when landing on the downside. In this case, pull in your clutch (so as not to stall) and tap your rear brake. This will bring your nose down. Always try and land smoothly, this will make the whole process effortless. If you find your nose dropping too much in the air, compensate by blimping the throttle again, this will bring the nose up.
Getting air is the absolute ultimate adrenaline rush on a quad, but be very carefull. Start small and learn how to manipulate the bike in the air. Once you got that, you can go ahead and get your wings!!
Good luck.
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Stever6368
Aug 16, 2015 07:34 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
