RPM axle ?
Old Sep 8, 2002 | 08:59 PM
JayBR's Avatar
I installed my new axle a couple weeks ago with 1" spacers on each side. Tonight when I was adjusting my alignment I noticed that the quad was 1/2" wider on the left side due to the axle. Anyone else seen this?
I replaced the 1" spacer with a 1/2" at the left wheel and everything lines up properly now.
Old Sep 9, 2002 | 02:57 PM
special's Avatar
Mine is ok with the distance but the lock nut has to be retightened after each ride.
Old Sep 9, 2002 | 09:06 PM
cannondale27's Avatar
I have the lonestar axle its the same.I have one of the first axles and I noticed in the next batch the sprocket hub is way thicker moving the axle out to the right.I need to contact them to see about getting that hub and check whether there will be enough room left for the locknut.
Old Sep 12, 2002 | 11:22 PM
airtimehocutt's Avatar
does the lone star axle or rpm axle come with the sprocket holder? what the price for the rpm axle? any body having problems with the axle lock nut coming loose?
Old Sep 12, 2002 | 11:40 PM
JayBR's Avatar
The RPM comes with the sprocket hub installed and goes for $459. The locknut is extra but I don't remember how much, call R&S Performance.
Don't have enough time on mine to comment on the lock nut coming loose.
Old Sep 12, 2002 | 11:49 PM
mxmike's Avatar
I got the RPM with sprocket hub and lock nut for about $460 from r&s.
The lock nut always comes loose.It always backs off just enough to give slack in the break hub.I am going to try some lock tight on it.
Old Sep 13, 2002 | 10:04 AM
mxmike,
is it the stock lock nut backing off or the after market lock nut. the lonestar axle is $388 i wonder if it comes with the sprocket holder. probably so since they are such a pain to put on. any word on how the stock rear wheel hubs are holding up?
Old Sep 13, 2002 | 06:29 PM
mxmike's Avatar
I have the antifade lock nut that came with it.
Motown got a lonestar with sprocket hub no lock nut for about $440.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
