getting a clutch for polaris
Old Sep 18, 2002 | 08:12 PM
mainjet's Avatar
im getting a aaen clutch kit, how hard are they to put in.do u need any special tools.how much more power will i get from it.
Old Sep 18, 2002 | 10:07 PM
BUBASCRAMBLER's Avatar
No special tools needed, Just follow directions.
It will be helpful to have some assistance when winding secondary.
As far as performance, Have you did any other mods? If not are you getting the clutch kit for a stock machine? Most likely it will pull harder (You may loose some top end),By adding a clutch kit you are changing the gear ratios,through out the entire powerband. Depending on the kit you are getting it will do different things. When ordering did you tell AAEN what you had as far as Mods on the machine? Clutching should alway be re-done to match the New powerband of any Performance Mod you make.
maxjung
Jul 13, 2015 05:11 PM
clsharky
Jul 13, 2015 02:07 PM
Shifts
14
Jul 13, 2015 08:41 AM
200es
Jul 10, 2015 09:09 AM
Wnthunting
Jul 9, 2015 03:02 PM
