Scrambler Problem
Old Sep 22, 2002 | 06:38 PM
mojave300ex's Avatar
My buddies scrambler 400 has no power, he broke a belt and put a new one on now it won't take off good. Once you get it going it has power, my thoughts were low compression or somthing wrong with the belt.
Old Sep 22, 2002 | 06:54 PM
swampdonkeykiller's Avatar
I think a more likely cause is that he wore a groove into his drive or driven pulley, possibly from lack of cleaning of the clutch surfaces or from burning a belt. This causes your clutches to engage the pulleys at the same RPM, but they have less surface area of the belt to hold on to. Instead of grabbing your belt on its tappered sides as it was designed to, it grabs it at the flat side of the belt which is a smaller surface area. When you first start out, that is when you require the most grip on your belt to get things in motion and that is why it doesm't launch hard-it is likely slipping slightly.
Old Sep 22, 2002 | 07:13 PM
Ok I'll tear it apart and inspect them. I don't see how it could be possible for a rubber belt to wear a groove into a steel clutch?
Old Sep 23, 2002 | 11:28 AM
scramblered's Avatar
if the scram was running well and then turn bad after putting a new belt,it is probably the belt deflection not dialed-in for the secondary clutch,is the quad engage and go(foward) at idle?
always set the proper belt deflection after each belt test...
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
