Check your Battery!
Old Sep 23, 2002 | 09:06 AM
jcv400ex's Avatar
After hours of searching and 10 days at the local dealer....I found my stalling problem. My battery had 2 holes in it from rubbing on the front engine mounts. If you do find this. Here's the fix(I'll have pics tomorrow)
Remove the battery, loosen the 4 bolts holding the battery tray on, remove the 2 bolts closest to the engine. Put washers between the frame and the battery box to tilt the box away from the engine. With the battery in place, you want about a half an inch clearance. Re-install the bolts.
I am in the process of drawing up the plans for a aluminum battery box that will mount to the sub-frame if anyone is interested. It will allow you to run a stronger battery, I can't remember the numbers of the battery, but it has a good 90 cold cranking amps more of juice.
Old Sep 23, 2002 | 10:15 AM
RetroZ's Avatar
Let me know when you get the battery box done. I need some more cranking power for those dead engine starts. I just bought a 03 and it seems to start a little quicker than my 02. Might just be a fresher battery. I'm still running your radiator screen, it matches the red stripes on my 03 perfect.
bzdok1234
30
Feb 23, 2016 01:55 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
