HPD c.a.t.t.
Old Sep 24, 2002 | 11:24 PM
scramblered's Avatar
for custom aluminum thumb throttle,i use it for 1 season yet,the cable broke some weeks ago and i'll get new cable pretty soon so i was wondering if there is any fine tune specs to set the cable right,thanks.
Old Sep 24, 2002 | 11:38 PM
talonhawk's Avatar
I've had mine on all season and not had any problems with it.
It should have a wide variaty of adjustments.
Old Sep 26, 2002 | 11:40 PM
scrambansheeman's Avatar
yes mine broke quick also. you need to take a dremel or air grinder inside the housing and grind a route for the cable so it wont rub.
Old Sep 27, 2002 | 01:37 PM
modquad's Avatar
Also remember to lube the cable and inner workings of the assembly. I use Tri-flo (with teflon)displaces water also.
Ken
Old Sep 27, 2002 | 04:21 PM
thankx guys,it is done by now,i've made a new route for the cable and lube it pretty well,the trigger is very "free" now and work well,the SNAP times are back.
